Overheating after radiator relocate
2 reading
11K views 13 replies 4 participants last post by  GSXRMAN
First time on here...i have a 2017 maverick with about 25 hours on it.i installed a wild boar relocate kit and now having overheating problems.i bled the system per the manual and is still over heating,for some reason the passenger side of the radiator stays cold while the driverside is hot..i am thinking the system is not circulating.i am out of ideas and would apreciate any input or has anyone ran into this problem.
#5 ·
You probably have air in the system. If you relocated it to the back, elevate the rear of the machine and run it with the cap broke loose for at least 5 minutes. Then elevate the front and do the same. This should force the air pocket out thru the cap. Also look for any high spots in the water lines like going over a frame member etc. These high spots will trap air.
